Re: What wood to use
I used pressure treated Douglas Fir plywood, two pieces laminated. Don't believe what people say that resin will not stick to pressure treated ply. It is simply not true, it will stick the same as it will to regular ply as long as the pt ply is dry. I let mine dry for about six weeks indoors before it was dry enough. Try to find CCA treated ply it is better but is being phased out, if not you will have to use ACQ ply. If you choose to go the pt route, use stainless steel fasteners. At least you know this stuff will not rot.
Have a great day,
Rob.
