what would be considered high hours on a 3.0 merc?
purpony
Looking at a couple boats and one of them is a 99 searay 180 with a 3.0 merc and the owner is saying 1600 hrs.... seems high to me.
Owners saying - Just had new impeller and seals in lower end
thanks
alldodge
Sounds like a well taken care of boat (1600) but IMO if the engine has not been rebuilt it should be getting real close
Fastatv
thanks
It sounds high...the "1600" but, that's just a little over 100 hours per year. As someone said, certainly no biggy if it was taken care of. The 3.0L is a great little engine.
airdvr1227
I think hours is a huge misnomer when it comes to boat engines. Think about what 1600 hours represents on a typical 4 cyl engine. Let's say we got on the freeway and drove at 60 mph for 1600 hours. You'd have 96,000 miles on your car's engine. Anyone here believe a 4 cylinder motor is worn out at 96,000 miles? Granted it's a different atmosphere and cars run at a different RPM but still...
H20Rat
I tend to disagree...
A car driving at 60 mph is running around 8% load level. (at least that is what my scanguage shows for my 4 cylinder at 60) A boat engine is above 8% load level while idling in gear! VASTLY different load levels. Running on plane is going to be around 40% load level.
Lets compare gallons per hour to get an accurate comparison. My car at 60mph does around 30 mpg, so it is burning 2 gallons per hour. A mercruiser 3.0 at cruising speed, 30 mph, burns 6-8 gallons per hour depending on hull. So around 3-4 times as much fuel burnt for the same time, so you can expect roughly 3-4 times the wear. 1600 automotive hours might be the same as 4800 hours, or 300,000+ miles in your example above... That is coincides with the manufacturer recommended oil change intervals for marine engines vs auto.
thumpar
It is a little high but not to the point of needing a rebuild unless it was not taken care of. They are good for 2000+ hours easy. Just like anything it is about maintenance. My wifes 03 Suburban has 376000 miles on it and that is our tow rig.
Ayuh,.... I agree, that Hours don't mean Squat,..... If ya wanta know the Health of yer motor, do a Compression, 'n leak-down Tests,....
My ole 4.3LX is well over 1600 hours, headed for 2000 hours, 'n it's compression is still Strong,... mid 150s last test,...
HT32BSX115
Yup. 1600 hrs is not really a big deal at all. My last boat (1966 model) had the hr meter fail at 1500 hrs in the 1980's and I sold the boat in 2005.
compression, leakdown and idle oil pressure will tell you pretty much all you need to know about health of the engine.
redneck joe
not to derail thread, but OP may want to know as well - what is a leakdown test?
