Re: what would cause the motor to cut down to idle at WOT?
my 75hp force did the same thing and i had to replace the bulb i had no leak anywhere but the check valve in the bulb was bad. as already said as it starts to die pump the bulb and see if it picks back up if so could be a air leak cheack all clamps for tightness, replace the bulb.
