What would happen if......
NathanY
I used the mixed fuel out of my boat ( I just drained the tank to switch to synthetic) and ran it in my 99 Jimmy? I dont mean just dumping 50:1 fuel in it, I mean if I had half a tank, and I put the 50:1 on top of that. I have 16 gallons in 5 seperate gas cans, and I dont want to waste it.<br /><br />I did not know that I had 16 gallons of fuel in my boat. The fuel guage sender was not working, and I had filled it up the last time I went out, but I ran alot, and I mean alot. I guess in 4 hours of running, my boat used 2 gallons of fuel??? Any whoo I really dont want to waste this fuel, had I known that there was that much in there, I would have left it in there and ran on it longer. But on the upside, I fixed my fuel gauge, and now it works...
dolluper
Re: What would happen if......
The oxygen sensors would not like it they might cough and burb
dolluper
Burrp valves would love it injectors could be like bad plugs
Mark42
You can use it in your lawn mower. Mix it 50/50 with clean fuel and the motor won't even know.
ZmOz
Even at 50:1 it will run fine in a lawnmower...I often run mine that way. If you want to run it in your car I wouldn't use more than 1 gallon of mix to a full tank of gas.
Terry H
I do it a couple times a year Nate, I have a efi ford and I will put 5 gals of premix in with 15 gals of fresh gas, done good so far. Chief :) <br />That would be about 200:1 I think. Iam not recommending you do this, but if you do, thin it out as much as you can...
tfjrc2
Nate:<br />Never had a problem with the 27 gallon tank I have in the GMC.<br />I keep 40:1 mixed for weedwackers, chainsaws etc, in a 5 gal plastic container. At the end of season, I run the truck real low add the 40:1 few gallons and fill the rest up with 20 gals of fresh pump stuff.<br />So far, so good.
