Well, after finally getting our WOT problem resolved (thousands of dollars later), the bozos at the boat park damaged both stern drives after our first brief test run with two sweetly running engines :facepalm: We don't know who did this or how, but when we left the boat tied to the dock it was fine. When we visited the boat 5 days later it was obvious that there was a problem. One leg was tilted up higher than the other and both engines could be moved independent of each other by hand; in fact port was pointing in a different direction to starboard. Our mechanic removed both legs and this is what he found:
Apparently we need a new starboard transom plate, two new gimbal rings and repairs to the starboard propeller (the tip is slightly bent). My theory is that the boat may have been put in a different rack and lowered down so that the weight of the boat was on the legs, but all I really know is that it was fine when we left it and it has never been run aground or hit anything in the water. There was no visible external damage and no other marks on the boat.
Has anyone seen this type of damage before or have any theories on how this may have happened? We have filed an insurance claim and have been given a quote of $11,000 to fix it!! OUCH!
