Re: What year is my Evinrude 70?
Rod Holder<br /><br />You asked this question in former thread. I just started up my old 1974 25Hp i rebuild this winther. I can tell you,it does too. Water runs like from a slow crane, from the two holes just beyond the bolt lewel, where the lower unit bolts on. But lots of water at thermostat. ( you can check cooling by removing thermostat cover on smaller models) I guess this water leves the pump through a worn waterpump housing, at shaft, as i only replaced impeller.
