Re: What's it weigh??????????
it says this though in the description....
Power 135HP (101kW)
Full Throttle Range 4400 - 4800 RPM
Displacement 181CID (3.0L)
Engine Type I4
Bore & Stroke 4.00" X 3.60" (101mm X 91mm)
Compression Ratio 9.3:1
Fuel Requirement 87 Octane (R+M)/2
Fuel System 2V Carb with Turn Key Start & Mechanical Fuel Pump
Induction System Single Piece Iron Intake-Exhaust Manifold
Ignition System EST Analog with Distributor
Charging System 65 Amp/917 Watt Alternator
Water Drain System Quick-Disconnect Drain Hoses with Flush Feature
Exhaust System Iron Manifold with EDP Coating
Cooling System Thermostatically Controlled, Raw Water
Accessory Drive System V-Belt
Optional Power Steering Available
Recommended Engine Oil SAE 25W-40 NMMA Certified FC-W
Engine Guardian System Low Oil Pressure, High Coolant Temperature, Low Drive Lube
Alpha Ratios 2.0, 2.40(H)
Dimensions (LxWxH) in 29 x 26 x 21
Dimensions (LxWxH) mm 730 x 660 x 533
Weight w/ Alpha (lbs./kg) 635/288
Optional Freshwater Cooling Available
2nd to last line........
