Whats its called?
Realgun
Left side= Port<br />Right side= Starboard<br />Front of boat= Bow<br />Rear of boat= Stern<br />Rear where motor is mounted= Transom<br />Bottom most part of boat= Keel<br />Long pointed lines on botom of boat= Strake <br />Bottom most part of motor= Skeg<br />Pointy thing behind prop= Trim tab<br />Flat area on motor just above prop= Antiventlation plate<br />What covers the outboard motor= Cowl<br />Long hollow area under floor in middle of boat= bildge<br />Small hole in rear bottom= Drain<br />What fills small hole= Plug<br /><br />We know there are more please help get it in FAQ :)
Dunaruna
Re: Whats its called?
Originally posted by Realgun:<br /> Flat area on motor just above prop= Anti-Cavition plate<br /> :)
Anti ventilation plate :) <br /><br />Dashboard/steering wheel - Helm<br /><br />Sides of the boat - Gunwales (pronounced 'gunals')<br /><br />Aldo
QC
Originally posted by Realgun:<br /> Bottom most part of motor= Skeg<br />
I'd say bottom most part of outdrive or outboard<br /><br />
Originally posted by Realgun:<br /><br /> We know there are more please help get it in FAQ :)
Yes please :D <br /><br />This one drives me crazy:<br /><br />Rubber hangy down things that protect the side of the boat = fender<br /><br />They are not bumpers and definitely not bouys.<br /><br />Toward the stern = aft<br />Toward the bow = forward (correction please?)<br />Outside "rail" on bottom i.e. last strake = chine<br />Distance from waterline to the top of the Gunwale = freeboard
AMD Rules
In or towards the bows of a ship = fore
umblecumbuz
Pointy thing behind prop= Trim tab<br />Often now called trim fin to distinguish it from trim tabs like Bennetts.<br /><br />Toward the bow = forward (correction please?)<br />Pronounced 'For'ard'<br /><br />Seats across hull - thwarts<br /><br />Ropes - lines, warps, sheets<br /><br />Cupboards - lockers<br /><br />Dashboard - console<br /><br />Or just bookmark this site - it's got 'em all:<br />www.boatsafe.com/nauticalknowhow/gloss.htm
gutshot grouper
From dead ahead to two points abaft the starboard beam= danger zone. How many rookie boaters even know what to do about another craft approaching from this zone?
mattttt25
hood? how about cowl.<br /><br />gutshot- depends on target angle and bearing drift.
QC
Originally posted by gutshot grouper:<br /> From dead ahead to two points abaft the starboard beam= danger zone. How many rookie boaters even know what to do about another craft approaching from this zone?
Take responsibility to safely avoid the other craft, or something very similar. Anyway, this probably should be its own thread. It amazes me that this one rule is so unknown and misunderstood. Its even the reason for the different colors of your bow lights. I've just had to take the position that it is my responsibility to avoid any craft from any direction. :rolleyes: Fact is this is against the rules too as the craft that has the right of way should maintain its course to avoid any confusion . . .
CATransplant
Agreed. I have a single safety rule for boating:<br /><br />Rule 1: Every other craft on the water is going to try to kill you. Pay attention at all times and avoid them.<br /><br />I learned that from my Dad when I got my first motorcycle, and altered it slightly to suit boating. That rule has kept me out of trouble on both modes of transport.
QC
Originally posted by CATransplant:<br /> I learned that from my Dad when I got my first motorcycle
I've seen your picture, I didn't think they had motorcycles that far back . . . :p :p :D
CATransplant
Say, there, Quietcat...if that's a picture of the top of your head, you really oughta get that looked at.... :D
Twidget
Properly spelled bilge. Sorry dont mean to sound snotty. :) <br /><br />door = hatch<br />wall = bulkhead<br />toilet = head
QC
Originally posted by CATransplant:<br /> Say, there, Quietcat...if that's a picture of the top of your head, you really oughta get that looked at.... :D
I desrved that . . . :D Anyway, do you have a guess as to what that really is? I am kinda surprised more haven't asked, although I did post about it once. One said it was a massive zit getting popped . . . :eek: but that's not it either.
fixin
RODE - The anchor line and/or chain.<br />KEEL - The centerline of a boat running fore and aft; the backbone of a vessel.<br />DRAFT - The depth of water a boat draws.
QC
Originally posted by CATransplant:<br /> Looks like an aerial view of Lake Mead to me. Close?
Bingo, and you win one year free access to Iboats Boating Forums . . .
crazy charlie
Thing you stand over after having a 6 pack of Bud........Head Thing you kneel over after having a 12 pack of Bud........Head
