Trying to bring a '90 Johnson 120HP back to life that's been sitting for 5+ years. Problem appears to be spark, but in trouble shooting to that point, I did check the compression on two of the cylinders. Both read 90-100psi. Seemed low for a 2-stroke, but the shop manual said the actual value didn't matter as much as it being constant between the cylinders. I didn't test the other two once I figured out there was no spark, but reading the forums, people seem to be reporting 100+ psi as normal.
Any guidance on what the compression should look like? Are readings in the 90 psi range a death knell for the engine?
Thanks!
Thanks!
