What's the correct timing spec for my motor?
Dave1027
I have a '88 100hp Merc 4 cylinder 2+2. I also have the factory service manual for it but get this, it has two different specs for max timing. On one page it says 27 degress BTDC @ cranking (retards to 23 @5000 rpm). On another page it says 25 degress BTDC @ cranking (retards to 23 @5000 rpm). Must by a typo but which is wrong? So far I have erred on the side of caution setting it to 25 but I want to make sure I'm not shorting myself some extra performance. I'm thinking the later 115hp 4 cyl motors are probably the same spec?
oldman570
Re: What's the correct timing spec for my motor?
My manual says 27 BTDC at cranking speed with plugs removed and plug wires grounded out to block. I would set it alittle short and check it out when on the water as it should be 23 @ 5000 RPM when done. Adjusting on the water is not that bad to do with a kelper to drive the boat. The setting can be adjusted when the boat is dead still and not moving and checked again till you get the 23 @5000RPM.
This is just how I do it and the manual states to check it even after setting a cranking speed. JMO
Oldman570
Dave1027
Seems like all other Mercs retard 2 degrees at high rpm. How is it this motor retards 4 degrees?
oldman570
Most manuals will show a setting of 4 degress advanced as it will retard when running on the water. Thats why I always check the timming on the water after crank setting. That way you are running at top performace and not taking a chance of overtimming and burn the pistons or doing other damage. Diffrent CDI manufactures donot all build the boxes the same and a varyance can and will occure from one box to another.Testing on the water takes that question out of the diffrence of the timming when at WOT.
Oldman570
Faztbullet
The correct spec's is 25? BTDC at cranking speed and 23?at WOT...
