Re: what's the difference between a 85 and 115 up engines
The 85 has a standard bore of 3.375 and the 115 is 3.500. Besides the bore difference there are port area and port timing differences. Obviously the heads and carbs are different.
Yes, you can make a 115 out of your 85 block. Yes, you'll probably be dissapointed at the results vs. the work & $$.
