Re: whats this called and where can i get one.... PIC
They look like stock bayliner pieces, which came with many of their pkg boats. I have the same thing for my '97 2050CL. That back cover, is really just for mooring. The stock bayliner part is solid with no clear panel, so you can't see behind you. I have seen other brands of boats that do use a clear panel. <br /><br />We did try to use ours during a heavy downpour. Once we had it on, the insides quickly fogged up, and I had to stick my head out the zippered panel portion of the bimini top to see. <br /><br />Finding used ones, in good shape would probably be next to impossible. But if yours was a very popular model, they might show up on Ebay. Some bimini top sellers may have the original bayliner patterns, but they may not be much cheaper than going to a custom uphoulstry shop. <br /><br />Given your use for camping/sleeping, I think you would be better off with a squared off solution like QC posted. It will give you much more room to move around, than the slanted cover. You just might want more privicy curtains, and some screen netting for ventilation and keeping the bugs out. A good custom shop should be able to work with your particular needs.
