Wheel bearings on my Jimmy
BRG25
I have a 1998 GMC Jimmy that has gone through 4 sets of front wheel bearings. Granted it has 95,000 miles on it but come on!! This is killing me!! I've tried both OEM and aftermarket....doesn't matter. I actally had one self destruct on me and break into pieces. I love the truck but I can hear another bearing just begining to get loud again and I'm about ready to dump it and get something else. Anyone else have this problem?
SoulWinner
Re: Wheel bearings on my Jimmy
This is caused iether by the spindle or the installation of the bearing. The spindle acts as the inner race for both the inner and outter bearings. If the diameter of the spindle in incorrect there could be excessive slop in the bearing from istallation that would be apparent as play in the wheel/tire, or insufficient clearance for the bearing that would cause lubrication problems and would show up as the tire being difficult to turn due to binding of the bearing after preload is applied to the assembly.<br /><br />If the spindles mic out to spec, my guess is that when the bearings are installed, improper preload is applied during final assembly. It is critical for the life of the bearing and the health of the spindle that an accurate torque wrench is used to set the bearing preload as prescribed by the shop manual. Do it in the proper steps and make sure nothing changes the preload during final assembly of the washers, castle nut, etc. After assembly, rotate tire and see if there is any resistance which may indicate bind on the bearing, or preload too tight. Then see if the tire has latera motion (grab tire on the top and bottom and attemp to rock the top of the tire in and out of the fender well) to see if the preload is too loose.<br /><br />Lastly, make SURE you high temp grease and get a bearing packer. They are cheap, ensure the bearing is well packed with grease, and the high temp grease will not break down under the extreame tempratures generated by disk brakes. This is very important!<br /><br />If you do all this and the problems persist, sell the truck and get a Toyota :D
BRG25
I thought it was a sealed bearing? You can't buy just the bearing, have to get the whole knuckle? ..and they're not cheap!! I watched my mechanic torque the castle nut to spec. Also both left and right bearings have needed to be replaced at one time or another. Spindle?? Maybe but this started at about 30,000 miles and has continued. Maybe he torqued it too much...got me. I'm not a mechanic, I pay guys to figure it out for me :) Thanks for the reply.
gonfishn
I have always owned Jimmmys...but they have never got the bearing thing right..I just replaced front one a month ago which always seems to be on left side. With labor, cost 350 bucks of which i only paid 50$ because of extended warranty. when asked why, all i got was shrug from dealer who says its a normal thing with these Jimmy's.<br /><br />I have owned four now and everyone has had this problem. Even wrote gmac and response was that they are aware of problem and a thank you for bringing it to their attention.. Will still keep buying em but also will keep getting extended warranty..Why you may ask..I was t-boned once by a guy going over fifty miles an hour and frame durability saved my life...
BRG25
Yea, my Mom has a 2000 Blazer, just replaced hers at about 40,000 also under the extended warranty. Thing is I didn't get the extended warranty, wish I had now. The 4.3L V6 is a great engine and it does a pretty good job of pulling my boat (which has the same motor actually :D ) It's my understanding that the older Blazers/Jimmys had a good front end and then they changed it. I'm sure there must have been a good reason but...anyway I'm just ranting. Oh well...upward and onward.
