Re: wheels getting too hot
I didn't see where he had drums in the first place so that's probably not the issue. If they changed from drums to discs, the entire backing plate would have been changed as well and he didn't mention that.
I have discs on one axle of my trailer and if I come off the road and go directly into the water they will steam a bit. Granted, it takes 5-10 minutes to get the boat ready once I get to the ramp so they do cool a bit beforehand.
If everything has been replaced and was done correctly and the brakes are actually malfunctioning, look at what is causing the brakes to drag. Is your trailer level when you tow or is it tilting downward towards the hitch. That can compress the master cylinder. Do you have a shock in the coupler to help absorb some of the jolt when the master cylinder extends? It may be bad. Or simply, do you ride the brakes and overwork the brakes? Continual light braking will heat up discs very quickly.
One last thing- trailer discs tend to be much lighter than the tow vehicle discs which means they will be less effective as a heat sink- that is it will take less heat to make them hot than a big rotor you would find on a truck. Pads are little, rotors are smaller, less surface area, higher temps...
UFM82
