When I start the engine steering cylinder immediately extends
AMMO DAWG
I put a marine power 5.7 engine in my 1999 Rinker and replaced the Merc outdrive with a Volvo DP-SM dual prop. All has gone well until I started the engine and attempted to bleed the steering system. As soon as I start the engine the steering cylinder immediately extends by itself and I have to fight it to turn the wheel the other direction (Port). I got the steering cylinder on eBay, was advertised as slightly used. I have the GM steering pump that came with the engine, it's not a Volvo steering pump, don't think that should matter. Really appreciate any insight you can provide on possible things I should do to resolve this. Thanks in advance.
Ayuh,..... Boats use a different pressure relief valve in the P/S pump,....
'n, the wrench flats on the cylinder's actuator valve need to be straight up, 'n down,....
AMMO DAWG
Thanks Bondo, the pump is for marine applications, can you give me more info on the wrench flats, you don't happen to have a diagram. Again, thanks for the quick reply
AMMO DAWG
Unfortunately, no love on the vertical flat, mine was completely vertical. Just as a side note I went through my Volvo workshop manual and there was no mention of the flats being vertical, not sure if it was omitted or there cylinder has a different design. Not sure where to go from here. I would just swap out the steering cylinder if they weren't so dang expensive. Any suggestions appreciated.
ptj11
I have the same problem in my 2000 5.7GS DP SXM. Getting a pressure test gauge today to verify that that the pump is good. I pulled the low pressure hose off of the oil cooler and briefly ran the motor. Fluid comes out fine so I assume that the pump is good but I want to check it anyway. I removed the oil cooler and it looks fine. I'm thinking the steering ram is bad or blocked/contaminated etc.I will report back later after I test the pump.
