SeaMasterZ@aol.com
- May 21, 2003
- 1,924
which side to put the larger outboard? the 33 and 40 horse are dimentionally similar, but there is that 7 horse difference ... I was thinking put the 40 horse on the side I am on<br /><br />also, do you line up the cavitation plate with the lowest part of the hull,, or go for the middle? (twin motors are on each side of the transom, where the distance to the bottom of the boat is less than at the keel, so line up at the inner edges of the cav plate level with the keel)<br /><br />thanks<br /><br />PS where is a good place to get the steering set up for a twin sixties OMC on a cable steering set up?
