Thank you, we think we do perfect maintance can we do better,we only use 100% synthetic, marine two stroke oil, marine gear lube, tested with 10% water contamination and marine fogging oil. Is spray fogging oil the best, we can do, ten seconds in each carb, five seconds in each cylinder, with the piston all the way in before you spray Yam has a product called Yamalube- EFI engine storage fogging oil, one quart in two gallon gas can, put a wye close to engine wine a piece of fuel line going into the two gallon gas can fogging oil mixture. For example, we use our boat every weekend, I wish, when we are done Sunday night, we do one of the the two fogging oils, spray or in gas or will 25:1 synthetic two stroke work the same run for five minutes until Smokey turn off motor, The yam fogging oil is a petroleum base product,we would rather not use. Lube the motor every weekend, to extend engine life, the rings, and not dry starts on Saturday morning. Time or money are not a factor .What is perfect
