When removing the reed valve assembly on a 9.9 do you need to replace the gasket or apply sealant
909
When reassembling ? Motor is a 1999 9.9 Yamaha MSHX .
I want to convert the 9.9 to a 15 by expanding the reed valve limiter spacing from 1.5 mm to 6mm and also by removing the rev limiter .
Anyone familiar with 9.9's ?
Here's a picture of the reed valve assembly removed
Note the black sealant. Also note the left side is the 9.9 side unmodified 1.5 mm. The right side is the modified 15 side 6 mm.
99yam40
try to reuse it and see, I would
not sure how much a new seal would cost you tho on something that old
909
You're probably right. It's old and will likely tear. What kind of sealant is this.
99yam40
service manual should have that info
My C40 does not have that type of gasket so my manual does not show any sealent in that area
