jtexas
 - Oct 13, 2003
 - 8,646
I use a deep cycle battery exclusively for the T/M.  After most outings even high winds & a lot of use it usually measures around 12 to 12.5 volts, rarely under 12.  Should I charge this battery before every trip, or should I discharge it more between charges?<br /><br />Also, is there some advantage to using the 2-Amp setting vs. the 15A on the charger?<br /><br />thanks,<br />jtw
