When You Winterize This Fall, Make Sure You Do This While Draining Your Motor
Taylor_T
Hey guys,
Just wanted to give a piece of advice for winterizing your boat this fall.
As you pull plugs to drain the water out of your motor's cooling system, take a piece of wire and poke it around in the drain holes to make sure nothing is blocking the water from draining out.
I was draining the water out of the cooling system on my motor this afternoon, and almost didn't do this. Then thought I better make sure, so I took a coat hanger and stuck it into each drain plug hole. To my surprise, on one of the manifolds, I stuck the hanger in and a fair amount of water came out that otherwise would have sat there and froze over the winter.
Easy to do, and you might be glad you did.
Blind Date
Good tip. With the 5.7 in my SeaRay it seems to always be the engine block drain on the port side that's plugged.
viper1216
What if you can't get to the drain hoses? I have 2010 mercruiser 3.0 and it has 2 blue hoses that are the drains. No way to really get up there to the block.
four winns 214
Good info for the newbie (as I was 10 years ago) and a good reminder for the rest of us. Just about every time I have drained the block on my 1984 Merc 228R, water flow on at least one side was obstructed by tiny bits of debris. I keep a six inch piece of stiff wire in my boat tool box that I use to poke into the drain. The flow of water instantly goes from a dribble to a stream.
H@ystack
Meanwhile, us florida boys are going "What's this winterizing thing". . Haha, seriously though, A little 120 psi air pressure helps too. Rubber tip on a rubber hose blows well.
Ayuh,..... I have a 3" deck screw that lives on the intake manifold, Just for pokin' out the drains,....
Take the hoses off, toss 'em, 'n use brass pipe plugs,....
