Where are all the grease points for Force 90 Outboard? Winterizing soon!
royal-direct
Just about to winterize my 1990 Force 90 Outboard, and just wanted to grease everywhere as well. First time winterizing myself, but I think i have a good idea of how to fog, fuel stabilize, and change lower unit oil.
It seems that grease is not a regular winterization step, but I'd like to do it.
So, if someone knows how to grease, and where, it would be greatly appreciated! (or any other tips about winterization (i've read most of the related posts on here...)) thanks!
further
Re: Where are all the grease points for Force 90 Outboard? Winterizing soon!
First time winterizing as well - I got a Clymers manual - it has about every grease point shown/illustrated and also gets fairly detailed on winterizing. If you live in a cold climate, you may want to flush with anti-freeze with one of those flushing systems or do like John from md on here recommends, get a kethcup bottle, and use it to squirt antifreeze in the thermostat plug on top of the block or into the tstat housing. Any water left inside can freeze and cause damage when it expands.
