Re: Where are the hydraulic trim's check valves?
Its a 96 wellcraft excel i/o mercruiser V6 vortex. I tried using the trouble shooting but i'm not really getting anywhere. Up works every time, when I hit the down button the hydraulic motor sounds like its running but the trim won't go down. If I keep clicking it over and over and over it'll finally start to drop. The other day I started turning the large bolts on the side, a little hydraulic fluid leaked out (tspn) I tightened everything back up and she worked first try, then didn't work again. So I when back and moved the bolt again, and she moved again first try but again wouldn't move after that. The hydraulic fluid is a pinkish white, which I feel is a bad thing. Should I drain it and put in new fluid or oil?
