All I see is a notch....no scale. Is that notch TDC, or is it the correct timing mark to line the notch in the pulley up with? Or is the scale there, and I'm just not looking at the right angle? <br /><br />I put it in base timing mode, and adjusted the timing to line up the notch on the pulley with the other notch. The thing was running better before....it now backfires occasionally.<br /><br />Thanks
