Where can I buy Yamaha tools?
warren631
Where can I buy a bearing housing puller for the lower unit for a T8ELH ? I have tried all the online parts places. Is there a standard puller that will do the job? I think the Yamaha part numbers are:
Bearing housing puller claw........90890-06564
Stopper guide plate......................90890-06501
Center bolt.....................................90890-06504
Thanks!
lakensea
Um - how about calling your local Yamaha dealer and ordering them?
99yam40
Talk to some techs to see what they use to pull them.
I know nothing about your little motor, but some prop shaft bearings carriers are pulled by slide hammer hooked to the shaft itself.
no idea if that is what you are trying to pull or if that will be a good way on that motor
