tigerfishes
- Jun 29, 2010
- 18
I purchased a 1977 Century Raven 200 with a OMC 190hp ford 302 and a OMC 175hp outdrive. the part number on the outdrive is 981059 and SN# is W127305. not sure about the engine and where to find this info. what has me baffled is everytime i try to look up this sterndrive all the numbers start with "99xxxx". i'm assuming that the stern drive is not the original since the motor is 190hp and the outdrive is 175hp. is this a OMC 400 or 800?
I have a manual on it's way....
I would like to put new wires, plugs, rotor and cap, fuel and oil filter, and oil in it before running it out on the water.
is there someplace i can go to find out all the information about this boat from when it was new? like which prop i should be using? now i can only get a 14 x 14 or a 14x16... but which one? i was told that based on the age of the boat... not the outdrive and shouldn't it be matched to the outdrive? see my problem?
anyone know where i can find a description of the part numbers and this phantom "98" number?
thanks!
thanks!
