Re: where can i get a new trim/tilt??
Thats right, on the front right corner of the reservoir there's 2 screws...one sets just below the other, the lower one is the fill hole...and as stated previously, the upper one is the vent for the reservoir...fill it with the 30w nondetergent just till the fluid touches the bottom of the hole...you will need to locate the bleeders (one up and one down bleeder screw on each ram) these can be identified by the "straight" screwdriver head...(there is some "allen head set-screws" by the bleeder screws...thats NOT the bleeders) the "down" bleeder screw is on top of the rams and the "up" bleeder screw location is the side of the ram facing towards the transom...once you verify fluid level, slightly open the "down" bleeders on the top of the rams...Using your controller push the "down" button, don't just hold the button in...pulse it, 2-3 seconds on and let up and do it some more..till you see fluid and air coming out of the bleeder...the bleeders don't need to be opened to far, they don't have many threads...a couple of turns out should be plenty to pass the air and fluid...do this and see what happens...if it starts to pump fluid to the rams you will hear the pump start to "tighten up"...tells you its starting to pump fluid..
