Where can I get a wiring diagram for an 85 hp evinrude
outboards115
Hi,
I've just been given a 1968 85 hp evinrude and all the wiring insulation has cracked and corroded. Some wires have got that bad that they've broken off. It would be extreemly heplful if anyone could help me out.
The model number is 85893A.
The serial sumber is E02728.
nwcove
Re: Where can I get a wiring diagram for an 85 hp evinrude
if you already havent......have a look at the top secret file at the beginning of this forum.
outboards115
where is the top secret file. I couldn't find it.
F_R
Here ya go----
outboards115
Thanks for the diagram.
Just a question, what is the box with the purple, black and two red wires coming out?
I hope its nothing to do with the ignition because the one on m,y outboard has the wires corroded down to the box!:(
outboards115
Also if it is not anything to do with the ignition, is there any way I can by-pass it?
outboards115
is the motor going to be able to run without part 38?
boobie
No..........
outboards115
is there anywere I can get a new part for it cheap.
boobie
You could try some different outboard dlr's in your area and you may find one.
F_R
Actually, that is the very heart of the battery CD ignition system. It is called the amplifier.
outboards115
Hi,
Thanks, I think I might have found a way to repair it by soldering the small amount of wire left over and use heat-shrink tubing as an insulator. it should work.
outboards115
And if worst comes to worst I'll buy a new amplifier.
outboards115
would this diagram of a 1968 100 hp johnson be the same as mine?68_100hp_V4.jpg
outboards115
Heres a link to an ebay search on the part for this outboard and I found this "Starter pack" johnson/evinrude starter pack in working order to suit all v4 outboards 68 to 84 | eBay. It wrote "For sale is starter pack to suit most v4 outboards from 68 through to 84, after this they used cdi unit setups. Sold as is condition, no returns, no warranty, will post at buyers exspense."
My question is, will this work on my outboard.
outboards115
F_R
Question #1, no that 100hp you posted is NOT the same. It has a pulse pack, you have an amplifier. A pulse pack is triggered by a magnetic sensor, an amplifier is triggered by breaker points.
Question #2, No that is a pulse pack. See #1. Besides the pulse packs weren't used that many years. Buying a used one that is not guaranted to work is a big gamble. I don't even buy lottery tickets, and sure as hang wouldn't buy that.
outboards115
Ok, thanks.
They say that it will fit this motor but it doesn't have the same connectors like the origonal one.
If I did buy one of these CDI amlpifyiers, how would I set it up on this motor. I would greatly appreciate it if anyone could let me know what to buy and how to set it up.
