Where can i get longer steering cable for Evinrude 35853R?
infowire
I have a 14' foot boat and i need like 6 inch more cable for the electronic tilt and trim. I wish there were cable extensions.
Chris1956
You should post this in the Johnson/evinrude forum, and say it is for trim/tilt. As it reads, it is for a steering cable. PTT cables are usually just 3 wires. What part of the wiring harness do you need an extension for?
infowire
That turns the actual motor. I don't know how else to call it.
GA_Boater
You need a wiring harness extension. Not a steering cable, throttle or shift cable. But purely a guess on my part.
Take a picture to clear this up.
infowire
The electric tilt will set motor 5.5 inches back so I'm worried because i don't have wiggle room ... maybe 2"
roscoe
Boat-Rotary-Steering-Cables/dm/cart_id.925679143--session_id.990456739--view_id.246976
or........
Boat-Rack-Pinion-Steering-Cables/dm/cart_id.925679143--session_id.990456739--view_id.246969
infowire
I'm guessing that's a rotary no feed back.
Which one do i choose ?
