Where did the RPM's go?
ae708
My boat... 1998 Manta Ray 17'9 with 3.0 Mercruiser I/O, 19 pitch prop used to run, with just me in it, about 48mph at 4900 RPM. Last time out it started great, ran fine up to about 42mph and 4400 RPM (appx) No skipping or misfiring, just runs out of top end. Put on new prop.. same thing... any suggestions..help.
Ribfan
Re: Where did the RPM's go?
Do you leave your boat on the water, or have since you last took it out..<br /><br />Stupid question i know, but you would be surprised how much crap grows underneath. and causes speed and RPM loss.<br /><br />If not could be alot of things
ae708
No.. the boat is trailered..bottom is clean as a pin. Can bad gas cause this without causing a miss in the engine?
D
DJ
Guest
ae,<br /><br />I believe your top rate rpm is 4400 (maybe 4600). Anything over that is not good for the engine.<br /><br />Boats tend to gain weight, over the season. Gear added, bilge water, etc.
