where do I add fluid to the power tilt and trim?
mikesea
Re: where do I add fluid to the power tilt and trim?
after you raise the engine,you should find a screwed plug on the resovior,which is opposite the tnt motor,fill til it overflows,replace plug,run up and down a few times ,refill if needed
