Where do I find a replacement bow switch panel frame?
TheMan_90241
My 87 Champion has a bow mounted switch panel. The panel is mounted to a plastic frame that screws down to the surface and is recessed about two inches. So, I don't need the panel per-se, I only need the plastic frame that is a deteriating rapidly. it drops into a cavity measuring approximately 10 inches x 4 inches. It flush mounts with an approximiate 3/4 flange and is recessed about 2 inches into the sidewall of the bow. Any ideas where I can get a replacement panel frame would be greatly appreciated. Thanks, Terry G.
rndn
Re: Where do I find a replacement bow switch panel frame?
I just made something similar for my Crestliner. The plastic was all cracked and falling apart. I had a piece of nylon cutting board and cut it to fit. It fits so good that you would honestly think it came with the boat.
