where do i put the fluid in
thenovascotian
I have 1975 merc 650 blueline and i think the hydraulic fluid is low where do i put in and do i have to bleed the system?
Chris1956
Re: where do i put the fluid in
Yes, you need to bleed the system. The top right of the pump/resevoir system has a stainless slotted screw, which is the fill. Check the current fluid. If brown adn clear, top it off with 5W-30 motor oil. If red and clear, use ATF.
