Where do these washers go ?
byson2
96 VP Cobra Sx. I removed the outdrive last fall to replace the bellows. I'm putting it back together and have no idea where these two washers go. I did remove the hinge pin bolt but don't think they go back there. They also don't appear to fit on the hydraulic ram shaft. Any ideas ?
BRICH1260
They look like two of the six washers that go with the six drive holding nuts.
Sunken Ship
Place the bar ("hinge pin") inside the two hydraulic rams that runs through the out drive. Bar will stick out about an 1/8" on each side Next, place one washer (in question) on one side and the second on the other side. Finally, place the two clips on each end on the outside of the two washers.
byson2
I figured it out. They go with the hinge pin bolt right next to the teflon bushing on the inside. Thanks
