1987 Wellcraft with a 260 merc I/O
Engine Serial # 0B489983
Last season I had this issue where my tach wouldn't work upon start up and then start working 5-10min into my trip and be fine up until the engine got cold and then it would do it again. I took the tach out of the dash and cleaned the terminals thinking it may be the tach itself but to no avail.
Now I am thinking there may be a lose connection or bad ground in the wire or wires that connect to the distributor? I checked the only wiring diagram I have for the boat but did not happen to see which wire off the Thunderbolt IV runs the tach.
I seem to think that the gray wire that is affixed to the negative side of my coil may run the tach, but I am unsure.
Does anyone know where I should be looking?
