Where is 0 on Mercruiser 120 timing tab (image included)?
justthisguyyaknow
My timing tab (shown below) is very worn, and I'm missing two key pieces of information:
#1. Where is 0 at on the tab?
#2. What the the increments of the lines on the tab (I assume 2 degrees each)?
It's a 1969 Mercruiser 120
Does anyone have this info?
Don S
Re: Where is 0 on Mercruiser 120 timing tab (image included)?
attachment.php
Here is a picture from the manual.
attachment.php
justthisguyyaknow
Wow, looking at the picture I can see the partial 0 easier than looking at the tab with the naked eye. Poor eyesight I guess.
The manual picture does make it easier.
Do you know if the marks are, in fact, at 2 degree increments?
Ayuh,... That is Correct...
justthisguyyaknow
Thanks everyone.
Well, it was advanced to 16 btdc (off the tab by about 2 degrees!).
I set it to spec, and strangely it runs a bit rougher when adjusted back to 8btdc (recommended spec from Merc Manual #1).
The plugs are old and a bit fouled, so I'll replace the plugs to see if that helps. I suspect that maybe the fouled plugs take an instant longer to develop a spark??? I doubt it would account for 8 degrees, but new plugs couldn't hurt.
Thanks again for the help.
