Re: Where is my charging wire? 1978 v4 85hp evinrude
yup. follow the Perko instructions. If you are trying to get your motor to charge an auxiliary battery, you might look into an isolator -- might not actually need the selector switch, depending on your application. I'm not sure what your output is, but probably not huge. I think a '72 had either a 9 or 15amp charging system, with the 15amp operating with a regulator, but maybe the '78 has a higher output.
