I want to check if my gear is stripped. I found that miniature oil pump at the end of the tube from the tank. I heard removing is an easy two bolt job. I found the bolt on the outside right. Where is the other one???? I think if I can get the pump off I can keep from making my dealers house payment. People talk about dealers charging 8 hours to remove the crank to change the gear to find the crank was never removed.
