jayhanig
Master Chief Petty Officer
- Jun 27, 2010
- 836
I had a hour meter added to my boat to keep up with time on the engine for scheduled maintenance purposes. Unfortunately, I've noted that the gauge is apparently tied in with what I will call the general 12 volt bus. In other words, if the main battery switch in the engine compartment is on, then the hour meter is active... which will eventually run my battery down as well as artificially show many more hours on the engine than actually exist. If that battery switch is on in the back, then everything electrical works in the boat, lights, electronics, gauges read, etc.
The existing gauges in my instrument panel include oil pressure, trim, water temp, voltage, fuel, speedometer, tach and of course the hour meter. Where is the best place to power that hour meter gauge from that will only be hot when the engine is actually turned on?
