Re: Where is the cooling water?
Does your engine have 2 ports at the top of the lower unit leg.... Most of the forces do not have a telltale on them from the factory, Most people add them to the engine... Yes when the engine is running make sure your water supply from the muffs is set to full from the hose and that you have a good fit with the muffs on the lower unit.. The water should exit from the prop and from the 2 ports on the back of the lower unit.. It wont come out as a stream from these 2 ports but more like a spray... If your over heat alarm isnt going off and it works.. Im assuming the water pump impeller is still good in yours..
Good luck
