Where is the fume gas tank vent?
CVue
Just bought an center console boat, forgot to ask salesman where the gas fuel vent is. The gas tank is under the center console. I see the inlet to the tank then another small tube that runs back up to where you pump gas into. Do I need to open any vents when filling gas or keep it open? Other portables gas tank there is a vent you keep open so it doesn't build up in tank. Not sure on this one. Any help is appreciated.
GA_Boater
Sounds like the vent is in the fuel filler assembly. Built-in tanks don't have a closable vent like portable tanks.
CVue
So I am assuming I just pump gas into the tank and close it and run as is? My motor is an two strokes, would I just pull the mixing oil down the same fuel rube as well?
