Where is the Throttle Stop Screw?
let0927
I have a 1983 Suzuki DT75 and I am trying to time it. The manual says to adjust the throttle stop screw to 1000 rpms before adjusting the flywheel to 7 degrees ATDC. So where is the Throttle Stop Screw?
Thanks in advance.
Texasmark
Re: Where is the Throttle Stop Screw?
Pop the cowling. Move the throttle linkage and look at what's moving. Somewhere along one of the moving arms you should see a screw with a spring on it, maybe a nylon knurled end on it (for finger turning) that hits something else when the throttle is at or near it's lowest setting. Screw it in to increase rpm's.
Mark
