Where the horn?
dadoftim
Ok I am a newbe to my 89 60hp Johnson VRO. From reading here, I now know its suppose to "chirp" when the key is turned on and sound continuely when the tan temp sensor wire is grounded, I get nothing just silence. Is the horn internal to the VRO pump? Or is it in the control box? I am hoping some prevous owner disconnected it and it won't require replacing the $$$ VRO pump.
robert graham
Re: Where the horn?
Probably in your control box. When you ground your temp wire to test system be sure your ignition switch is "on" so the horn will sound. Good Luck!
