Where to Buy Fuel Lines
koolerb
I'm getting ready to put the carbs back on my 3 cyl, 1992 Johnson 60hp, and decided to replace the fuel lines. I've never had a problem getting parts for this motor before, but my local OMC dealer says he can't get them. The primer hoses are black, small diameter tubing. The main fuel supply hose looks like a pre-formed line. I would reluctantly just re-use the old hoses but I cut the main fuel line. Any idea where I can order these?
dc in ms
Re: Where to Buy Fuel Lines
I saw where Overtons sales fuel tubing. Also, you should be able to get some fuel line from West, BoatUS or even Boaters World. Good luck
seahorse5
The part numbers still look like they are available from Johnson. If you still can't get them from your dealer, then do the following:<br /><br />For the carb hoses: Cut to Length from #327228 -5/32 in. I.D. that your dealer should stock<br /><br />For primer lines: Cut to Length from #327229 - 0.0575 in. I.D.
koolerb
seahorse - Thanks for the info. Do you know if the hose from the fuel filter to carburetor splitter fitting is a formed hose, or does it just look that way?
