Where to find pressed in rubber hub?
mdrussell2
I have a mercury quicksilver laser II 48 16994 a40 24p prop it has a pressed in rubber hub that i spun last week. it has already been removed for the life of me i can not find a part number on the old one or find a replacement online does anyone know where to buy a press in hub. ps goes on 1991 blackmax xr4 150.
  • Like
Reactions: TLA
Re: Where to find pressed in rubber hub?
Ayuh,.... That answer seems to be a trade secret, of the Prop Shops,...
Soooo,,..... Call yer local Prop Shop...
mdrussell2
ive called a few they just tell me bring it in for 65 bucks theyll do it but wont tell what hub and hell ive already done the hard and nasty part removing it and cleaning it
  • Like
Reactions: TLA
Frank Acampora
HMS hubs, Marine City, Mi. hmshubs.com 810 765-8311. But remember with shipping the hub will cost upwards of 35 bucks so a prop shop may not be a bad idea.
If you have a 6 ton press and an old tapered roller bearing race you can press it in yourself with just a little soapy water for lubricant. The press does not need to be massive or expensive. One of those cheap Harbor Freight ones will do.
After pressing in, let it sit a day or two in the sun to work out the water and let the rubber "grab" the prop. If you use it immediately it may spin again.
  • Like
Reactions: TLA
