Where To Find Riser Fittings....
San_Diego_SeaRay
My new risers (1993 454) came with a plug, no actual inlet fitting. Need to unscrew the plug and add these fittings. Anyone know where to get these? Are they universal NPT fittings I might find at a good hardware store? If so, what size and thread?
Fun Times
iboats has this item too.:)
https://www.mercruiserparts.com/866725-ftg-strgt-3-4-npt
https://www.mercruiserparts.com/bam/subassembly/31808/961/140
1222-866725 FITTING, Straight (.750-1445084SS/ACT
$14.50$14.141
18-4461 (Sierra Marine Brass Connector is an equivalent hose fitting: 3/4" - 14NPT X 1" Hose (Corrosion Resistant Brass Fitting) Replaces: 22-807155, https://www.iboats.com/shop/sierra-hose-barb-18-4461.html
https://www.ebay.com/sch/i.html?_fr...cat=0&LH_TitleDesc=0&_osacat=0&_odkw=22-45084
https://www.ebay.com/sch/i.html?_fr...sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=+45084
https://www.ebay.com/sch/i.html?_fr..._sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=45084
San_Diego_SeaRay
Click image for larger version  Name:	Brass_Fittings.jpg Views:	2 Size:	345.6 KB ID:	10813870
As always thanks guys. I'm always so impressed with your knowledge and your willingness to share.
Found them at my local non-big chain hardware store. They were 3/4" thread diameter and the barb was 1" diameter.
As a side note to ponder, why aren't we concerned with two different metals existing right next to each other in a cavity that holds saltwater? Isn't there a chance of electrolysis with brass and cast iron?
alldodge
Yes if its brass, but if its bronze then no
You sure it would be 3/4 npt to 1 inch barb and not 3/4 barb or less? I'm not seeing a 1 inch ID hose going to a elbow, actually more like a 5/8 but no more then 3/4
San_Diego_SeaRay
So I shouldn't use these brass fittings?
Regarding hose diameter, my Serial Number is 0F009622. It's a 1993 454 non-MAG Bravo 3 setup (although I now have a Bravo 1 drive). The hose is highlighted in the picture here. I'm going off memory but I thought it was 1" ID. You don't think so?
alldodge
If its 1 inch ID then you have the right size, the older thermostat housing did use larger hoses
Did some research and the new ones being sold by Merc look just like the ones you have. The original had more copper in them and the part number was 22-866725
San_Diego_SeaRay
Thanks. I think I only work with old stuff... :joyous:
