Where to find them?
mh1042
2008 Rinker....when you open the window on a bowrider....there are two round bumperstops to stop the glass from hitting the boat....a superball cut inn half...where to find them...I have looked high and low..
GLENN M
Re: Where to find them?
in b.c we have home depot stores there must be 50 differant size pieces of rubber you could glue on and look original
Bifflefan
Your local boat dealer should be able to get ones that will work, even if they are not the factory ones for a Rinker.
MPII
Hello! I just spent some time searching and can't find them either. I don't actually know what their technical name is so I don't believe that I am even searching with the right criteria. Seems like they would be a common part....... Don S or Bond-o (moderators on the forum) may be able to tell you. If you figure it out please post the actual name and what they are called.
Bob's Garage
I decided to replace mine on our bowrider when the black began staining the fiberglass around it. I went to the hardware store and picked up a set of white bumper pads that were too small individually but put them together, bottom to bottom, and now I no longer get black streaks. Best of all, they are common and cheap enough to replace when needed.
2ndtry
Have you tried the superball cut it half? :D
