where to get power steering lines
bobboater1
my power steering lines are rusting bad on outside 89 merc 260 hp alpha 1 what do you look under to fine out where to buy lines.
thanks in advance...
bob
Re: where to get power steering lines
Wow,....... They Don't Give Away those High Pressure Lines,....... Do They....??.....
I Believe that the Low Pressure side can be rebuilt using Automotive Brakeline Ends......
I Think mine are 3/8th", double flare fittings,......Your's should be as well......
bobboater1
wow 2 hoses about $350 mines are rusty..maybe i will clean the rust off..or ebay.
what happens if you dont use power steering on a 19 ft speed boat???? will the steering be hard
just curious
bob
bobboater1
also at these hi prices can we just take these over priced lines to a hyd. shop and have them make us one . no way will it be over $75 each
bob
Don S
bob
Sure you can get one made. It's not a marine specific part that has to pass any fuel or elecrical tests, or be certified by the USCG.
tashasdaddy
hydrolic shop was going to be my suggestion.
