Where to locate prop size and pitch
LarryHale
I have a 1987 Johnson 50 HP with a dinged up prop and would like to change it to gain a bit of top end speed. It's mounted on a 1987 Henry O. Where on the prop can I locate the size and pitch? I've looked everywhere externally and can't find anything.
211libwtfo
Did you look on the inner circle around where the prop shaft would come through.
LarryHale
No, I haven't. The cup is pretty gummed up so I guess I'll have to clean it up to check. Thanks for the info.
as far as gaining top speed, if your WOT RPM is where it is supposed to be, you need more motor to go faster.
