chopper6322
- Jan 28, 2015
- 69
I have a 1990 Evinrude 70hp that idles very rough on muffs and shuts down as soon as i advance the throttle while in the water. I have between 110 and 115 psi on all 3 cylinders, the spark jumped the 7/16's gap on all 3 plugs so i'm down to fuel but not sure where to start, there doesn't appear to be any leaks, new boat side fuel lines and primer bulb, primer gets hard before the motor starts, and then just slightly softens when its running (which i believe is normal) I've replaced the pulse limiter and fuel filter on the motor and cleaned the carbs. adjusting the idle mixture screws seems to make no difference (they are currently set to 1 1/2 turns from seated) any ideas on where to start next? the link and sync. seems good according to the manual. what should i check next?
