wheres that water sposed to come out?
Gus Mortimer
I have just been trying to start my 82 merc 90 L6, being new to this motor I am unsure of where the inlets are for water. my I/O has an actual hose connection. <br /> I think it must be those fin looking holes on eithor side of the lower. but. If this is the place, and I put the muffs over them water should come out the "pee hole" when at idle? or at least out of the prop hub or somewhere right?? <br /> Not too worried about the impellor due to it needing to me changed anyhow, just want to kick it over.
phatmanmike
Re: wheres that water sposed to come out?
hey there junior, i have same motor although mine is the 115 IL6...1977 vintage. <br /><br />anywho... yes, those fin like holes just a few inches above the prop, put the muffs on those...
you should be, if it isnt pumping water, your motor will get hot, quick, that is a big motor and needs a lot of liquid to cool the beast. water should come out the starboard side, just under the lower cowl hood, and also with the exhaust<br /><br />mikey
Gus Mortimer
so I have water coming from nowhere...maby a tricle from the hub but thats it.<br /> This motor has not been ran for about 5 or 6 years so the impeller probably self distructed on ignition. If this is the case will water come from anywhere or nowhere at all?<br /> I will be putting a new pump in. I am just wondering if no water at all is right or if I should be looking for blockage. I found those mud dauber wasp nest things in several places under the cowl. <br /> Also i can see light coming through the "pee hole" and no hose or anything of the sort. What should there be?
kenneymc
Blow it out with LP air. I hooked my compressor to the tell/tale outlet and gave it several good shots of air to make sure it was not clogged up. I also have a pressure gauge, so i blew air through the hose that runs from gauge to motor. Just disconnected hose from back of gauge.
Gus Mortimer
when you say gauge you mean a water pressure? if so I dont have one. the tell tale.. I can look down the rear of my cowl and see light coming through the hole, but I dont see any hose. there should be one right<br /> my seloc manual gives no diagram for the circulation of water :(
Gus Mortimer
so I am an idiot. I was looking at a cowl drain I think, now I see the tell tale over to the side a little.
kenneymc
yes, mine is on the starboard (right) side of the motor toward the rear. I just held the end of my air hose as best as i could to the tell/tale and gave it a few shots of air.<br /><br />yes, i mean water pressure gauge in my previous reply.
Gus Mortimer
cool I will try to blow it out. After properly locating the tell tale I did discover dried mud in there. <br /> do you have a temp guage? I would like to have one of those rather than a water pressure guage
kenneymc
no, I do not have a temp gauge. wish i did, think they would be a good tool to have. I am not even sure where the sender would attach on the motor. My SELOC manual does not go very in depth on that subject either. rest of the gauges i have a broken. guy i bought my boat from did not care about them, as long as it ran to get him to a fishin hole, that's all that mattered. I am slowly replacing them all as I get time.<br /><br />you could try running something small up in to the tell/tale to clean out the mud or whatever it is blocking it up. hopefullt it is not very far in there.
